Je n'arrive pas à compiler Aseprite
KhanCherAmi
je veut compiler Aseprite sur Ubuntu MATE 20.04,
mais quand j'entre la commande
ninja aseprite
j'ai cette erreur:
faucon@faucon-LIFEBOOK-A555:~/aseprite/build$ ninja aseprite
ninja: error: loading 'build.ninja': No such file or directory
J'ai donc essayé de réessayer de créer le fichier build.ninja avec cette commande mais en regardant les logs:
cmake -G Ninja -DLAF_BACKEND=skia ..
et dans les logs ils y avait plein d'erreurs, voici mes logs:
faucon@faucon-LIFEBOOK-A555:~/aseprite/build$ cmake -G Ninja -DLAF_BACKEND=skia ..
CMake Deprecation Warning at CMakeLists.txt:16 (cmake_policy):
  The OLD behavior for policy CMP0046 will be removed from a future version
  of CMake.
  The cmake-policies(7) manual explains that the OLD behaviors of all
  policies are deprecated and that a policy should be set to OLD only under
  specific short-term circumstances.  Projects should be ported to the NEW
  behavior and not rely on setting a policy to OLD.
-- Could NOT find CCache (missing: CCache_EXECUTABLE)
-- Symbol prefix:
-- Adding -lm flag.
-- Could NOT find TIFF (missing: TIFF_LIBRARY TIFF_INCLUDE_DIR)
-- Performing Test WEBP_HAVE_FLAG_SSE41
-- Performing Test WEBP_HAVE_FLAG_SSE41 - Failed
-- Performing Test WEBP_HAVE_FLAG_SSE41 - Success
-- Performing Test WEBP_HAVE_FLAG_SSE2
-- Performing Test WEBP_HAVE_FLAG_SSE2 - Success
-- Performing Test WEBP_HAVE_FLAG_MIPS32
-- Performing Test WEBP_HAVE_FLAG_MIPS32 - Failed
-- Performing Test WEBP_HAVE_FLAG_MIPS_DSP_R2
-- Performing Test WEBP_HAVE_FLAG_MIPS_DSP_R2 - Failed
-- Performing Test HAS_COMPILE_FLAG
-- Performing Test HAS_COMPILE_FLAG - Failed
-- Performing Test WEBP_HAVE_FLAG_NEON
-- Performing Test WEBP_HAVE_FLAG_NEON - Failed
-- Performing Test WEBP_HAVE_FLAG_MSA
-- Performing Test WEBP_HAVE_FLAG_MSA - Failed
-- curl version=[7.79.1-DEV]
-- CA path only supported by OpenSSL, GnuTLS or mbed TLS. Set CURL_CA_PATH=none or enable one of those TLS backends.
-- Enabled features: IPv6 unixsockets libz AsynchDNS Largefile alt-svc HSTS
-- Enabled protocols: DICT FILE FTP GOPHER HTTP IMAP MQTT POP3 RTSP SMTP TELNET TFTP
-- Enabled SSL backends:
-- Version: 6.2.0
-- Build type: RelWithDebInfo
-- CXX_STANDARD: 14
-- Required features: cxx_variadic_templates
-- Could NOT find LIBB2 (missing: LIBB2_LIBRARY LIBB2_INCLUDE_DIR)
-- Extended attributes support: Linux
-- ACL support: none
-- Could NOT find deflate (missing: DEFLATE_LIBRARY DEFLATE_INCLUDE_DIRS)
-- laf backend: skia
-- laf pixman: pixman
-- laf freetype: FREETYPE_LIBRARY-NOTFOUND
-- laf harfbuzz: HARFBUZZ_LIBRARY-NOTFOUND
-- skia dir:
-- skia library: SKIA_LIBRARY-NOTFOUND
-- skia library dir:
CMake Error at laf/CMakeLists.txt:87 (message):
  set SKIA_DIR/SKIA_LIBRARY/SKIA_LIBRARY_DIR to compile w/skia backend
-- Configuring incomplete, errors occurred!
See also "/home/faucon/aseprite/build/CMakeFiles/CMakeOutput.log".
See also "/home/faucon/aseprite/build/CMakeFiles/CMakeError.log".
je comprends rien à ce qui ce passe, s'il vous plaît aidez moi
tutoriel officiel de compilation d'Aseprite (github.com)
( désolé pour les oubli de majuscule ou des fautes de frappes je suis fatigué :/ )
  • Perplexe 1
