mise à niveau 14.04 et direct, grub rescue! pb après consultations de forums
Djalabal
bonjour!! après avoir mise à niveau mon elementary ,au redémarrage ,je tombe sur le "fameux" grub rescue... de l'aide please!!!!
Boot Repair Info :
Révélation
Boot Info Script 8f991e4 + Boot-Repair extra info      [Boot-Info 25oct2017]
============================= Boot Info Summary: ===============================
 => Grub2 (v2.00) is installed in the MBR of /dev/sda and looks at sector 1 of
    the same hard drive for core.img. core.img is at this location and looks
    for (,msdos1)/boot/grub. It also embeds following components:
    modules
    fshelp ext2 part_msdos biosdisk
 => Syslinux MBR (3.61-4.03) is installed in the MBR of /dev/sdb.
sda1: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  Grub2 (v1.99-2.00)
    Boot sector info:  Grub2 (v2.00) is installed in the boot sector of sda1
                       and looks at sector 569520 of the same hard drive for
                       core.img. core.img is at this location and looks for
                       components:
                       modules
    Operating System:  Ubuntu 14.04.5 LTS
    Boot files:        /boot/grub/grub.cfg /etc/fstab
                       /boot/grub/i386-pc/core.img
sda2: __________________________________________________________________________
    File system:       Extended Partition
    Boot sector type:  Unknown
    Boot sector info:
sda5: __________________________________________________________________________
    File system:       ext4
    Boot sector type:  -
    Boot sector info:
    Operating System:
    Boot files:
sda6: __________________________________________________________________________
    File system:       swap
    Boot sector type:  -
    Boot sector info:
sdb1: __________________________________________________________________________
    File system:       vfat
    Boot sector type:  SYSLINUX 4.03 2010-10-22 ........>..sr>..........:...0...~.....~...f...M.f.f....f..0~....>E}.u......
    Boot sector info:  Syslinux looks at sector 33512 of /dev/sdb1 for its
                       second stage. SYSLINUX is installed in the  directory.
                       No errors found in the Boot Parameter Block.
    Operating System:
    Boot files:        /boot/grub/grub.cfg /syslinux.cfg /casper/vmlinuz.efi
                       /EFI/BOOT/grubx64.efi /ldlinux.sys
============================ Drive/Partition Info: =============================
Drive: sda _____________________________________________________________________
Disk /dev/sda: 298.1 GiB, 320072933376 bytes, 625142448 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Partition  Boot  Start Sector    End Sector  # of Sectors  Id System
/dev/sda1    *          2,048    78,125,055    78,123,008  83 Linux
/dev/sda2          78,127,102   625,141,759   547,014,658   5 Extended
/dev/sda5          78,127,104   617,187,327   539,060,224  83 Linux
/dev/sda6         617,189,376   625,141,759     7,952,384  82 Linux swap / Solaris
Drive: sdb _____________________________________________________________________
Disk /dev/sdb: 3.8 GiB, 4102887936 bytes, 8013453 sectors
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
/dev/sdb1    *             63     8,013,452     8,013,390   c W95 FAT32 (LBA)
GUID Partition Table detected, but does not seem to be used.
Partition  Attrs   Start Sector    End Sector  # of Sectors System
/dev/sdb1   +B R             34     5,119,999     5,119,966 EFI System partition
Attributes: R=Required, N=No Block IO, B=Legacy BIOS Bootable, +=More bits set
"blkid" output: ________________________________________________________________
Device           UUID                                   TYPE       LABEL
/dev/loop0                                              squashfs
/dev/sda1        95535da3-41cc-440c-9bf2-11d822521086   ext4
/dev/sda5        0406c6c5-5dc6-49fc-bd0c-9360e3d7d56f   ext4
/dev/sda6        a715c5ca-84aa-4066-b883-6554924dd7a1   swap
/dev/sdb1        2636-C174                              vfat       UUI
/dev/sr1         2007-08-29-11-31-12-                   iso9660    U3 System
========================= "ls -l /dev/disk/by-id" output: ======================
total 0
lrwxrwxrwx 1 root root  9 Nov  2 20:19 ata-PIONEER_DVD-RW_DVRTD11RS_SDC1822909 -> ../../sr0
lrwxrwxrwx 1 root root  9 Nov  2 20:29 ata-WDC_WD3200BPVT-22JJ5T0_WD-WXC1EC1UHJC2 -> ../../sda
lrwxrwxrwx 1 root root 10 Nov  2 20:29 ata-WDC_WD3200BPVT-22JJ5T0_WD-WXC1EC1UHJC2-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Nov  2 20:29 ata-WDC_WD3200BPVT-22JJ5T0_WD-WXC1EC1UHJC2-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Nov  2 20:29 ata-WDC_WD3200BPVT-22JJ5T0_WD-WXC1EC1UHJC2-part5 -> ../../sda5
lrwxrwxrwx 1 root root 10 Nov  2 20:29 ata-WDC_WD3200BPVT-22JJ5T0_WD-WXC1EC1UHJC2-part6 -> ../../sda6
lrwxrwxrwx 1 root root  9 Nov  2 20:29 usb-SanDisk_Cruzer_00001814C7704593-0:0 -> ../../sdb
lrwxrwxrwx 1 root root 10 Nov  2 20:29 usb-SanDisk_Cruzer_00001814C7704593-0:0-part1 -> ../../sdb1
lrwxrwxrwx 1 root root  9 Nov  2 20:19 usb-SanDisk_Cruzer_00001814C7704593-0:1 -> ../../sr1
lrwxrwxrwx 1 root root  9 Nov  2 20:29 wwn-0x50014ee60267012a -> ../../sda
lrwxrwxrwx 1 root root 10 Nov  2 20:29 wwn-0x50014ee60267012a-part1 -> ../../sda1
lrwxrwxrwx 1 root root 10 Nov  2 20:29 wwn-0x50014ee60267012a-part2 -> ../../sda2
lrwxrwxrwx 1 root root 10 Nov  2 20:29 wwn-0x50014ee60267012a-part5 -> ../../sda5
lrwxrwxrwx 1 root root 10 Nov  2 20:29 wwn-0x50014ee60267012a-part6 -> ../../sda6
================================ Mount points: =================================
Device           Mount_Point              Type       Options
/dev/loop0       /rofs                    squashfs   (ro,noatime)
/dev/sdb1        /cdrom                   vfat       (ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
=========================== sda1/boot/grub/grub.cfg: ===========================
# DO NOT EDIT THIS FILE
# It is automatically generated by grub-mkconfig using templates
# from /etc/grub.d and settings from /etc/default/grub
### BEGIN /etc/grub.d/00_header ###
if [ -s $prefix/grubenv ]; then
  set have_grubenv=true
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="0"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function recordfail {
  set recordfail=1
  if [ -n "${have_grubenv}" ]; then if [ -z "${boot_once}" ]; then save_env recordfail; fi; fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
if [ x$feature_default_font_path = xy ] ; then
   font=unicode
else
insmod part_msdos
insmod ext2
set root='hd0,msdos1'
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1  95535da3-41cc-440c-9bf2-11d822521086
else
  search --no-floppy --fs-uuid --set=root 95535da3-41cc-440c-9bf2-11d822521086
fi
    font="/usr/share/grub/unicode.pf2"
fi
if loadfont $font ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=fr_FR
  insmod gettext
fi
terminal_output gfxterm
if [ "${recordfail}" = 1 ] ; then
  set timeout=30
else
  if [ x$feature_timeout_style = xy ] ; then
    set timeout_style=menu
    set timeout=10
  # Fallback normal timeout code in case the timeout_style feature is
  # unavailable.
  else
    set timeout=10
  fi
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/05_debian_theme ###
set menu_color_normal=white/black
set menu_color_highlight=black/light-gray
if background_color 0,0,0; then
  clear
fi
### END /etc/grub.d/05_debian_theme ###
### BEGIN /etc/grub.d/10_linux ###
function gfxmode {
    set gfxpayload="${1}"
    if [ "${1}" = "keep" ]; then
        set vt_handoff=vt.handoff=7
    else
        set vt_handoff=
    fi
if [ "${recordfail}" != 1 ]; then
  if [ -e ${prefix}/gfxblacklist.txt ]; then
    if hwmatch ${prefix}/gfxblacklist.txt 3; then
      if [ ${match} = 0 ]; then
        set linux_gfx_mode=keep
      else
        set linux_gfx_mode=text
      fi
    else
    fi
  else
  fi
else
fi
export linux_gfx_mode
menuentry 'Ubuntu' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-95535da3-41cc-440c-9bf2-11d822521086' {
    recordfail
    load_video
    gfxmode $linux_gfx_mode
    insmod gzio
    insmod part_msdos
    insmod ext2
    else
    fi
    linux    /boot/vmlinuz-3.13.0-133-generic root=UUID=95535da3-41cc-440c-9bf2-11d822521086 ro  quiet splash $vt_handoff
    initrd    /boot/initrd.img-3.13.0-133-generic
submenu 'Options avancées pour Ubuntu' $menuentry_id_option 'gnulinux-advanced-95535da3-41cc-440c-9bf2-11d822521086' {
    menuentry 'Ubuntu, avec Linux 3.13.0-133-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.13.0-133-generic-advanced-95535da3-41cc-440c-9bf2-11d822521086' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        echo    'Chargement de Linux 3.13.0-133-generic…'
        echo    'Chargement du disque mémoire initial…'
    menuentry 'Ubuntu, with Linux 3.13.0-133-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.13.0-133-generic-recovery-95535da3-41cc-440c-9bf2-11d822521086' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        linux    /boot/vmlinuz-3.13.0-133-generic root=UUID=95535da3-41cc-440c-9bf2-11d822521086 ro recovery nomodeset
    menuentry 'Ubuntu, avec Linux 3.2.0-126-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.2.0-126-generic-advanced-95535da3-41cc-440c-9bf2-11d822521086' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        echo    'Chargement de Linux 3.2.0-126-generic…'
        linux    /boot/vmlinuz-3.2.0-126-generic root=UUID=95535da3-41cc-440c-9bf2-11d822521086 ro  quiet splash $vt_handoff
        initrd    /boot/initrd.img-3.2.0-126-generic
    menuentry 'Ubuntu, with Linux 3.2.0-126-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.2.0-126-generic-recovery-95535da3-41cc-440c-9bf2-11d822521086' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        linux    /boot/vmlinuz-3.2.0-126-generic root=UUID=95535da3-41cc-440c-9bf2-11d822521086 ro recovery nomodeset
    menuentry 'Ubuntu, avec Linux 3.2.0-67-generic' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.2.0-67-generic-advanced-95535da3-41cc-440c-9bf2-11d822521086' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        echo    'Chargement de Linux 3.2.0-67-generic…'
        linux    /boot/vmlinuz-3.2.0-67-generic root=UUID=95535da3-41cc-440c-9bf2-11d822521086 ro  quiet splash $vt_handoff
        initrd    /boot/initrd.img-3.2.0-67-generic
    menuentry 'Ubuntu, with Linux 3.2.0-67-generic (recovery mode)' --class ubuntu --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-3.2.0-67-generic-recovery-95535da3-41cc-440c-9bf2-11d822521086' {
        recordfail
        load_video
        insmod gzio
        insmod part_msdos
        insmod ext2
        else
        fi
        linux    /boot/vmlinuz-3.2.0-67-generic root=UUID=95535da3-41cc-440c-9bf2-11d822521086 ro recovery nomodeset
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/30_uefi-firmware ###
### END /etc/grub.d/30_uefi-firmware ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
=============================== sda1/etc/fstab: ================================
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    nodev,noexec,nosuid 0       0
# / was on /dev/sda1 during installation
UUID=95535da3-41cc-440c-9bf2-11d822521086 /               ext4    errors=remount-ro 0       1
# swap was on /dev/sda6 during installation
UUID=a715c5ca-84aa-4066-b883-6554924dd7a1 none            swap    sw              0       0
=================== sda1: Location of files loaded by Grub: ====================
           GiB - GB             File                                 Fragment(s)
   8.200210571 = 8.804909056    boot/grub/grub.cfg                             1
  12.131900787 = 13.026529280   boot/grub/i386-pc/core.img                     1
  36.000007629 = 38.654713856   boot/vmlinuz-3.13.0-133-generic               14
  16.117904663 = 17.306468352   boot/vmlinuz-3.2.0-126-generic                 3
  15.528102875 = 16.673173504   boot/vmlinuz-3.2.0-67-generic                  9
  36.000007629 = 38.654713856   vmlinuz                                       14
  16.117904663 = 17.306468352   vmlinuz.old                                    3
  28.051784515 = 30.120374272   boot/initrd.img-3.13.0-133-generic            186
   8.078845978 = 8.674594816    boot/initrd.img-3.2.0-126-generic             40
  31.462120056 = 33.782194176   boot/initrd.img-3.2.0-67-generic               4
  28.051784515 = 30.120374272   initrd.img                                    186
=========================== sdb1/boot/grub/grub.cfg: ===========================
if loadfont /boot/grub/font.pf2 ; then
    set gfxmode=auto
    insmod efi_gop
    insmod efi_uga
    insmod gfxterm
fi
menuentry "Try Ubuntu without installing" {
    set gfxpayload=keep
    linux    /casper/vmlinuz.efi  file=/cdrom/preseed/ubuntu.seed boot=casper quiet splash ---
    initrd    /casper/initrd.lz
menuentry "Install Ubuntu" {
    set gfxpayload=keep
    linux    /casper/vmlinuz.efi  file=/cdrom/preseed/ubuntu.seed boot=casper only-ubiquity quiet splash ---
menuentry "OEM install (for manufacturers)" {
    set gfxpayload=keep
    linux    /casper/vmlinuz.efi  file=/cdrom/preseed/ubuntu.seed boot=casper only-ubiquity quiet splash oem-config/enable=true ---
menuentry "Check disc for defects" {
    set gfxpayload=keep
    linux    /casper/vmlinuz.efi  boot=casper integrity-check quiet splash ---
============================== sdb1/syslinux.cfg: ==============================
default menu.c32
prompt 0
menu title UNetbootin
timeout 100
label unetbootindefault
menu label Default
kernel /ubnkern
append initrd=/ubninit file=/cdrom/preseed/ubuntu.seed boot=casper quiet splash ---
label ubnentry0
menu label ^Help
kernel /ubnkern
label ubnentry1
menu label ^Try Ubuntu without installing
kernel /casper/vmlinuz.efi
append initrd=/casper/initrd.lz file=/cdrom/preseed/ubuntu.seed boot=casper  quiet splash ---
label ubnentry2
menu label ^Install Ubuntu
append initrd=/casper/initrd.lz file=/cdrom/preseed/ubuntu.seed boot=casper only-ubiquity  quiet splash ---
label ubnentry3
menu label ^Check disc for defects
append initrd=/casper/initrd.lz boot=casper integrity-check  quiet splash ---
label ubnentry4
menu label Test ^memory
kernel /install/mt86plus
label ubnentry5
menu label ^Boot from first hard disk
kernel /ubnkern
label ubnentry6
menu label Try Ubuntu without installing
label ubnentry7
menu label Install Ubuntu
label ubnentry8
menu label OEM install (for manufacturers)
append initrd=/casper/initrd.lz file=/cdrom/preseed/ubuntu.seed boot=casper only-ubiquity quiet splash oem-config/enable=true ---
label ubnentry9
menu label Check disc for defects
=================== sdb1: Location of files loaded by Grub: ====================
            ?? = ??             boot/grub/grub.cfg                             1
================= sdb1: Location of files loaded by Syslinux: ==================
            ?? = ??             syslinux.cfg                                   1
            ?? = ??             ldlinux.sys                                    1
            ?? = ??             menu.c32                                       1
============== sdb1: Version of COM32(R) files used by Syslinux: ===============
 menu.c32                           :  COM32R module (v4.xx)
======================== Unknown MBRs/Boot Sectors/etc: ========================
/dev/sdb1: unknown GPT attributes
d000000000000005
Unknown BootLoader on sda2
00000000  fa 1b 2e 67 13 97 53 56  fb 1d c7 7b 16 1e f9 6f  |...g..SV...{...o|
00000010  03 c7 bf 30 8c e1 77 f3  0c 32 f4 a8 cf ad eb a7  |...0..w..2......|
00000020  3f a7 ff 86 b7 e3 23 6a  ff e5 f8 c1 3c 5f 3e 8d  |?.....#j....<_>.|
00000030  14 5e e3 72 56 f8 95 ab  96 d3 9f e0 f2 8c 54 fd  |.^.rV.........T.|
00000040  18 5e de 35 7e f4 b9 bc  3e 2b fd f0 bd 38 9f 69  |.^.5~...>+...8.i|
00000050  31 8c cf 24 35 02 fc 8c  b9 65 85 d9 a5 05 e8 5b  |1..$5....e.....[|
00000060  c4 c7 26 0a 59 59 f3 8a  4a 8a b3 e8 73 f3 ac 2c  |..&.YY..J...s..,|
00000070  21 eb c1 85 59 53 2d f3  0a ca ad 96 b2 71 85 f8  |!...YS-......q..|
00000080  a5 6f b9 c0 12 64 cd b3  58 d3 cb 0a 16 5a ca 26  |.o...d..X....Z.&|
00000090  e3 2a 0f 47 e6 14 96 94  5b c6 95 14 17 5b 72 e8  |.*.G....[....[r.|
000000a0  50 0c 8e 2e b7 14 e7 4e  cd 5e a4 06 2d b8 6c 05  |P......N.^..-.l.|
000000b0  e1 49 25 b9 9e 94 a5 ec  0b 63 1e c2 cf 7b 5b b3  |.I%......c...{[.|
000000c0  29 b3 e4 2c d4 b0 29 b4  64 2f b4 a8 6c a0 24 a5  |)..,..).d/..l.$.|
000000d0  d6 7c 3a ca 05 8b 42 9f  ce 42 69 80 6b 71 49 96  |.|:...B..Bi.kqI.|
000000e0  7a 38 0c 52 e5 60 fc 48  21 2f af d0 56 9e 8f df  |z8.R.`.H!/..V...|
000000f0  91 e6 94 2e 16 2c 15 05  56 a1 9c 3e af cd 13 f2  |.....,..V..>....|
00000100  e8 e3 62 88 29 cb c9 2f  13 ca 0b e6 e1 49 0c 10  |..b.)../.....I..|
00000110  2c 46 ca 52 9b b5 1c f8  42 05 e1 89 02 f9 0b b2  |,F.R....B.......|
00000120  f0 a3 67 c1 5a 52 58 b2  c8 52 c6 3e 40 45 5a 5c  |..g.ZRX..R.>@EZ\|
00000130  5b cb c9 cf 2d 80 f4 d6  5c 3c c5 24 0f 12 e6 08  |[...-...\<.$....|
00000140  45 96 22 64 92 47 f5 24  14 b1 2f 55 51 86 6c 2b  |E."d.G.$../UQ.l+|
00000150  7e ec 6a 29 5e 88 f4 20  b4 90 5d 98 5d 56 24 e4  |~.j)^.. ..].]V$.|
00000160  d1 17 be 50 18 fa 9e 18  09 41 a2 3c 2e 27 7e 03  |...P.....A.<.'~.|
00000170  4b 95 96 95 85 e5 e2 8d  56 94 5d 50 2c e4 95 59  |K.......V.]P,..Y|
00000180  2c 80 ae a0 93 26 b2 2c  b4 c2 96 95 35 b7 bc 9c  |,....&.,....5...|
00000190  11 01 aa 38 57 4d 96 53  6e cb a2 95 bc 85 05 e5  |...8WM.Sn.......|
000001a0  05 25 73 b3 a1 8d b3 50  70 fc a6 16 64 c2 43 0c  |.%s....Pp...d.C.|
000001b0  8a cb f1 54 0e 24 82 2a  63 c2 8c 85 f2 e3 00 fe  |...T.$.*c.......|
000001c0  ff ff 83 fe ff ff 02 00  00 00 00 68 21 20 00 fe  |...........h! ..|
000001d0  ff ff 05 fe ff ff 02 68  21 20 00 60 79 00 00 00  |.......h! .`y...|
000001e0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  |................|
000001f0  00 00 00 00 00 00 00 00  00 00 00 00 00 00 55 aa  |..............U.|
00000200
=============================== StdErr Messages: ===============================
File descriptor 9 (/proc/5428/mounts) leaked on lvs invocation. Parent PID 12673: bash
File descriptor 63 (pipe:[50861]) leaked on lvs invocation. Parent PID 12673: bash
ADDITIONAL INFORMATION :
=================== log of boot-repair 20171102_2029 ===================
boot-repair version : 4ppa63
boot-sav version : 4ppa63
boot-sav-extra version : 4ppa63
glade2script version : 3.2.3~ppa4
Warning: Unable to open /dev/sr1 read-write (Read-only file system).  /dev/sr1 has been opened read-only.
Error: /dev/sr1: unrecognised disk label
Partition 2 does not start on physical sector boundary.
boot-repair is executed in live-session (Ubuntu 16.04.3 LTS, xenial, Ubuntu, x86_64)
CPU op-mode(s):        32-bit, 64-bit
initrd=/casper/initrd.lz file=/cdrom/preseed/ubuntu.seed boot=casper  quiet splash --- BOOT_IMAGE=/casper/vmlinuz.efi
ls: cannot access '/home/usr/.config': No such file or directory
=================== os-prober:
/dev/sda1:Ubuntu 14.04.5 LTS (14.04):Ubuntu:linux
=================== blkid:
/dev/sda1: UUID="95535da3-41cc-440c-9bf2-11d822521086" TYPE="ext4" PTTYPE="dos" PARTUUID="0000039d-01"
/dev/sda5: UUID="0406c6c5-5dc6-49fc-bd0c-9360e3d7d56f" TYPE="ext4" PARTUUID="0000039d-05"
/dev/sdb1: LABEL="UUI" UUID="2636-C174" TYPE="vfat" PARTUUID="00072170-01"
/dev/loop0: TYPE="squashfs"
/dev/sda6: UUID="a715c5ca-84aa-4066-b883-6554924dd7a1" TYPE="swap" PARTUUID="0000039d-06"
/dev/sr1: UUID="2007-08-29-11-31-12-" LABEL="U3 System" TYPE="iso9660"
1 disks with OS, 1 OS : 1 Linux, 0 MacOS, 0 Windows, 0 unknown type OS.
=================== sda1/etc/grub.d/ :
drwxr-xr-x  2 root root              4096 Oct 26 12:54 grub.d
total 72
-rwxr-xr-x 1 root root  9791 Jul 17 05:59 00_header
-rwxr-xr-x 1 root root  6058 May 13  2015 05_debian_theme
-rwxr-xr-x 1 root root 11608 Jul 17 05:59 10_linux
-rwxr-xr-x 1 root root 10412 Jul 17 05:59 20_linux_xen
-rwxr-xr-x 1 root root 11692 Jul 17 05:59 30_os-prober
-rwxr-xr-x 1 root root  1418 Jul 17 05:59 30_uefi-firmware
-rwxr-xr-x 1 root root   214 Jul 19  2013 40_custom
-rwxr-xr-x 1 root root   216 Jul 17 05:59 41_custom
-rw-r--r-- 1 root root   483 Jul 19  2013 README
=================== sda1/etc/default/grub :
# If you change this file, run 'update-grub' afterwards to update
# /boot/grub/grub.cfg.
# For full documentation of the options in this file, see:
#   info -f grub -n 'Simple configuration'
GRUB_DEFAULT=0
#GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=true
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR=`lsb_release -i -s 2> /dev/null || echo Debian`
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
GRUB_CMDLINE_LINUX=""
# Uncomment to enable BadRAM filtering, modify to suit your needs
# This works with Linux (no patch required) and with any kernel that obtains
# the memory map information from GRUB (GNU Mach, kernel of FreeBSD ...)
#GRUB_BADRAM="0x01234567,0xfefefefe,0x89abcdef,0xefefefef"
# Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
# The resolution used on graphical terminal
# note that you can use only modes which your graphic card supports via VBE
# you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
# Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
# Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
# Uncomment to get a beep at grub start
#GRUB_INIT_TUNE="480 440 1"
=================== UEFI/Legacy mode:
This live-session is not in EFI-mode.
EFI in dmesg.
[    0.000000] ACPI: UEFI 0x00000000A6FFD000 000236 (v01 ACRSYS ACRPRDCT 00000001 1025 00040000)
SecureBoot maybe enabled.
=================== PARTITIONS & DISKS:
sda1    : sda,    not-sepboot,    grubenv-ok    grub2,    grub-pc ,    update-grub,    64,    with-boot,    is-os,    not--efi--part,    fstab-without-boot,    fstab-without-efi,    no-nt,    no-winload,    no-recov-nor-hid,    no-bmgr,    notwinboot,    apt-get,    grub-install,    with--usr,    fstab-without-usr,    not-sep-usr,    standard,    not-far,    notbiosboot, /mnt/boot-sav/sda1.
sda5    : sda,    maybesepboot,    no-grubenv    nogrub,    no-docgrub,    no-update-grub,    32,    no-boot,    no-os,    not--efi--part,    part-has-no-fstab,    part-has-no-fstab,    no-nt,    no-winload,    no-recov-nor-hid,    no-bmgr,    notwinboot,    nopakmgr,    nogrubinstall,    no---usr,    part-has-no-fstab,    not-sep-usr,    standard,    farbios,    notbiosboot, /mnt/boot-sav/sda5.
sda    : not-GPT,    BIOSboot-not-needed,    has-no-EFIpart,     not-usb,    not-mmc, has-os,    2048 sectors * 512 bytes
=================== parted -lm:
BYT;
/dev/sda:320GB:scsi:512:4096:msdos:ATA WDC WD3200BPVT-2:;
1:1049kB:40.0GB:40.0GB:ext4::boot;
2:40.0GB:320GB:280GB:::;
5:40.0GB:316GB:276GB:ext4::;
6:316GB:320GB:4072MB:linux-swap(v1)::;
BYT;
/dev/sdb:4103MB:scsi:512:512:msdos:SanDisk Cruzer:;
1:32.3kB:4103MB:4103MB:fat32::boot, lba;
BYT;
/dev/sr1:7340kB:unknown:2048:2048:unknown:Unknown:;
=================== lsblk:
KNAME TYPE FSTYPE     SIZE LABEL
sdb   disk            3.8G
sdb1  part vfat       3.8G UUI
sr0   rom            1024M
loop0 loop squashfs   1.4G
sda   disk          298.1G
sda2  part              1K
sda5  part ext4       257G
sda1  part ext4      37.3G
sda6  part swap       3.8G
sr1   rom               7M
KNAME ROTA RO RM STATE   MOUNTPOINT
sdb      1  0  1 running
sdb1     1  0  1         /cdrom
sr0      1  0  1 running
loop0    1  1  0         /rofs
sda      1  0  0 running
sda2     1  0  0
sda5     1  0  0         /mnt/boot-sav/sda5
sda1     1  0  0         /mnt/boot-sav/sda1
sda6     1  0  0         [SWAP]
sr1      1  0  1 running
=================== mount:
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=1923108k,nr_inodes=480777,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=387832k,mode=755)
/dev/sdb1 on /cdrom type vfat (ro,noatime,fmask=0022,dmask=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
/dev/loop0 on /rofs type squashfs (ro,noatime)
aufs on / type aufs (rw,noatime,si=e0feebadb4d7fbe7)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=24,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=15011)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
mqueue on /dev/mqueue type mqueue (rw,relatime)
tracefs on /sys/kernel/debug/tracing type tracefs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,relatime)
tmpfs on /run/user/999 type tmpfs (rw,nosuid,nodev,relatime,size=387832k,mode=700,uid=999,gid=999)
gvfsd-fuse on /run/user/999/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=999,group_id=999)
/dev/sda1 on /mnt/boot-sav/sda1 type ext4 (rw,relatime,data=ordered)
/dev/sda5 on /mnt/boot-sav/sda5 type ext4 (rw,relatime,data=ordered)
=================== ls:
/sys/block/sda (filtered):  alignment_offset badblocks bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range holders inflight integrity power queue range removable ro sda1 sda2 sda5 sda6 size slaves stat subsystem trace uevent
/sys/block/sdb (filtered):  alignment_offset badblocks bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range holders inflight integrity power queue range removable ro sdb1 size slaves stat subsystem trace uevent
/sys/block/sr0 (filtered):  alignment_offset badblocks bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range holders inflight integrity power queue range removable ro size slaves stat subsystem trace uevent
/sys/block/sr1 (filtered):  alignment_offset badblocks bdi capability dev device discard_alignment events events_async events_poll_msecs ext_range holders inflight integrity power queue range removable ro size slaves stat subsystem trace uevent
/dev (filtered):  autofs block bsg btrfs-control bus cdrom cdrw char console core cpu cpu_dma_latency cuse disk dri drm_dp_aux0 dvd dvdrw ecryptfs fb0 fd full fuse hidraw0 hidraw1 hidraw2 hidraw3 hidraw4 hidraw5 hpet hugepages hwrng i2c-0 i2c-1 i2c-2 i2c-3 i2c-4 i2c-5 i2c-6 initctl input kmsg kvm lightnvm log mapper mcelog media0 mei0 mem memory_bandwidth mqueue net network_latency network_throughput null port ppp psaux ptmx pts random rfkill rtc rtc0 sda sda1 sda2 sda5 sda6 sdb sdb1 sg0 sg1 sg2 sg3 shm snapshot snd sr0 sr1 stderr stdin stdout uhid uinput urandom usb userio v4l vfio vga_arbiter vhci vhost-net video0 zero
ls /dev/mapper:  control
=================== df -Th:
Filesystem     Type      Size  Used Avail Use% Mounted on
udev           devtmpfs  1.9G     0  1.9G   0% /dev
tmpfs          tmpfs     379M  6.1M  373M   2% /run
/dev/sdb1      vfat      3.9G  1.6G  2.4G  40% /cdrom
/dev/loop0     squashfs  1.5G  1.5G     0 100% /rofs
aufs           aufs      1.9G   71M  1.8G   4% /
tmpfs          tmpfs     1.9G  276K  1.9G   1% /dev/shm
tmpfs          tmpfs     5.0M  4.0K  5.0M   1% /run/lock
tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
tmpfs          tmpfs     1.9G  256K  1.9G   1% /tmp
tmpfs          tmpfs     379M  100K  379M   1% /run/user/999
/dev/sda1      ext4       37G   23G   12G  67% /mnt/boot-sav/sda1
/dev/sda5      ext4      253G  240G  798M 100% /mnt/boot-sav/sda5
=================== fdisk -l:
Disk /dev/loop0: 1.4 GiB, 1532116992 bytes, 2992416 sectors
Disklabel type: dos
Disk identifier: 0x0000039d
Device     Boot     Start       End   Sectors   Size Id Type
/dev/sda1  *         2048  78125055  78123008  37.3G 83 Linux
/dev/sda2        78127102 625141759 547014658 260.9G  5 Extended
/dev/sda5        78127104 617187327 539060224   257G 83 Linux
/dev/sda6       617189376 625141759   7952384   3.8G 82 Linux swap / Solaris
Disklabel type: dos
Disk identifier: 0x00072170
/dev/sdb1  *       63 8013452 8013390  3.8G  c W95 FAT32 (LBA)
=================== Suggested repair
The default repair of the Boot-Repair utility would reinstall the grub2 of sda1 into the MBR of sda.
Additional repair would be performed: unhide-bootmenu-10s
=================== User settings
The settings chosen by the user will not act on the boot.
pardon de mettre le boot repair info comme ca....... je galere......
Modifié par Le PoissonClown
Mise en forme
  • 2 semaines plus tard...
Salut !
Désolé de mon absence.
Je suis loin d'être expert avec Linux. Je lis "SecureBoot maybe enabled." As-tu essayé de désactiver le SecureBoot depuis le BIOS ?
Le 02/11/2017 à 21:42, Djalabal a dit :
Pas de souci, j'ai édité pour mettre le rapport dans un volet déroulant.
