Bsod MACHINE_CHECK_EXCEPTION
Devii974
Bonjour, j'ai un soucis avec des Bsod  MACHINE_CHECK_EXCEPTION
J'ai comme config:
  • Carte mère asus maximus VIII hero
  • Processeur intel I5 6600K
  • Carte graphique 1050TI Gigabite G1 Gamin 4gb
  • Alim corsair TX550M
  • Barette ram Ballistix ddr4 4x4gb 3000udimm
  • Et une carte son Asus xonar dgx
Whocrashed me dit:
Révélation
Windows version: Windows 10 , 10.0, build: 17134
Windows dir: C:\WINDOWS
Hardware: ASUSTeK COMPUTER INC., MAXIMUS VIII RANGER
CPU: GenuineIntel Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz Intel586, level: 6
4 logical processors, active mask: 15
RAM: 17091174400 bytes total
Crash Dump Analysis
Crash dumps are enabled on your computer.
Crash dump directories:
C:\WINDOWS
C:\WINDOWS\Minidump
On Sun 24/06/2018 17:48:04 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\062418-22609-01.dmp
This was probably caused by the following module: hal.dll (hal+0x40D05)
Bugcheck code: 0x9C (0x0, 0xFFFFE6002394BC80, 0x0, 0x0)
Error: MACHINE_CHECK_EXCEPTION
file path: C:\WINDOWS\system32\hal.dll
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: Hardware Abstraction Layer DLL
Bug check description: This bug check indicates that a fatal machine check exception has occurred.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: hal.dll (hal!HalBugCheckSystem+0x18B5)
On Sun 24/06/2018 16:57:37 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\062418-25640-01.dmp
Bugcheck code: 0x9C (0x0, 0xFFFFF8002EDEBB80, 0x0, 0x0)
Conclusion
3 crash dumps have been found and analyzed. No offending third party drivers have been found. Connsider using WhoCrashed Professional which offers more detailed analysis using symbol resolution. Also configuring your system to produce a full memory dump may help you.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
Ainsi que Windbg:
Révélation
Microsoft (R) Windows Debugger Version 10.0.15063.468 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Kernel address space is available, User address space may not be available.
Symbol search path is: srv*
Executable search path is:
Windows 10 Kernel Version 17134 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 17134.1.amd64fre.rs4_release.180410-1804
Machine Name:
Kernel base = 0xfffff800`484a2000 PsLoadedModuleList = 0xfffff800`4885c1f0
Debug session time: Sun Jun 24 17:48:04.937 2018 (UTC + 2:00)
System Uptime: 0 days 0:36:25.624
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 9C, {0, ffffe6002394bc80, 0, 0}
Probably caused by : intelppm.sys ( intelppm!MWaitIdle+23 )
Followup:     MachineOwner
3: kd> !analyze -v
MACHINE_CHECK_EXCEPTION (9c)
A fatal Machine Check Exception has occurred.
KeBugCheckEx parameters;
    x86 Processors
        If the processor has ONLY MCE feature available (For example Intel
        Pentium), the parameters are:
        1 - Low  32 bits of P5_MC_TYPE MSR
        2 - Address of MCA_EXCEPTION structure
        3 - High 32 bits of P5_MC_ADDR MSR
        4 - Low  32 bits of P5_MC_ADDR MSR
        If the processor also has MCA feature available (For example Intel
        Pentium Pro), the parameters are:
        1 - Bank number
        3 - High 32 bits of MCi_STATUS MSR for the MCA bank that had the error
        4 - Low  32 bits of MCi_STATUS MSR for the MCA bank that had the error
    IA64 Processors
        1 - Bugcheck Type
            1 - MCA_ASSERT
            2 - MCA_GET_STATEINFO
                SAL returned an error for SAL_GET_STATEINFO while processing MCA.
            3 - MCA_CLEAR_STATEINFO
                SAL returned an error for SAL_CLEAR_STATEINFO while processing MCA.
            4 - MCA_FATAL
                FW reported a fatal MCA.
            5 - MCA_NONFATAL
                SAL reported a recoverable MCA and we don't support currently
                support recovery or SAL generated an MCA and then couldn't
                produce an error record.
            0xB - INIT_ASSERT
            0xC - INIT_GET_STATEINFO
                  SAL returned an error for SAL_GET_STATEINFO while processing INIT event.
            0xD - INIT_CLEAR_STATEINFO
                  SAL returned an error for SAL_CLEAR_STATEINFO while processing INIT event.
            0xE - INIT_FATAL
                  Not used.
        2 - Address of log
        3 - Size of log
        4 - Error code in the case of x_GET_STATEINFO or x_CLEAR_STATEINFO
    AMD64 Processors
        1 - Bank number
Arguments:
Arg1: 0000000000000000
Arg2: ffffe6002394bc80
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
DUMP_CLASS: 1
DUMP_QUALIFIER: 401
BUILD_VERSION_STRING:  17134.1.amd64fre.rs4_release.180410-1804
SYSTEM_MANUFACTURER:  System manufacturer
SYSTEM_PRODUCT_NAME:  System Product Name
SYSTEM_SKU:  SKU
SYSTEM_VERSION:  System Version
BIOS_VENDOR:  American Megatrends Inc.
BIOS_VERSION:  1902
BIOS_DATE:  06/24/2016
BASEBOARD_MANUFACTURER:  ASUSTeK COMPUTER INC.
BASEBOARD_PRODUCT:  MAXIMUS VIII RANGER
BASEBOARD_VERSION:  Rev 1.xx
DUMP_TYPE:  1
BUGCHECK_P1: 0
BUGCHECK_P2: ffffe6002394bc80
BUGCHECK_P3: 0
BUGCHECK_P4: 0
BUGCHECK_STR:  0x9C_GenuineIntel
CPU_COUNT: 4
CPU_MHZ: db0
CPU_VENDOR:  GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 5e
CPU_STEPPING: 3
CPU_MICROCODE: 6,5e,3,0 (F,M,S,R)  SIG: BE'00000000 (cache) BE'00000000 (init)
DEFAULT_BUCKET_ID:  WIN8_DRIVER_FAULT
PROCESS_NAME:  System
CURRENT_IRQL:  f
ANALYSIS_SESSION_HOST:  PCELINA
ANALYSIS_SESSION_TIME:  06-24-2018 18:14:37.0222
ANALYSIS_VERSION: 10.0.15063.468 amd64fre
BAD_STACK_POINTER:  ffffe6002394bc48
LAST_CONTROL_TRANSFER:  from fffff80048456d05 to fffff8004863a330
STACK_TEXT:
ffffe600`2394bc48 fffff800`48456d05 : 00000000`0000009c 00000000`00000000 ffffe600`2394bc80 00000000`00000000 : nt!KeBugCheckEx
ffffe600`2394bc50 fffff800`4845714f : 00000000`00000004 ffffe600`2394bf50 00000000`00000000 00000000`00000004 : hal!HalpMcaReportError+0xf5
ffffe600`2394bda0 fffff800`48457390 : ffff8382`060e28b0 ffffe600`2394bfd0 00000000`00000000 00000000`00000000 : hal!HalpMceHandlerWithRendezvous+0x12b
ffffe600`2394bdd0 fffff800`4864883b : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : hal!HalHandleMcheck+0x40
ffffe600`2394be00 fffff800`486484ff : 00000000`00000000 fffff800`4864847e 00000000`00000000 00000000`00000000 : nt!KxMcheckAbort+0x7b
ffffe600`2394bf40 fffff803`b2bc13f3 : fffff803`b2bc13b4 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x1bf
ffffba81`8c64f5e8 fffff803`b2bc13b4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`0000003a : intelppm!MWaitIdle+0x23
ffffba81`8c64f5f0 fffff800`48540fbf : 00000000`00000000 00000000`0000007d ffffe600`23945ec8 00000001`bdcf67d2 : intelppm!AcpiCStateIdleExecute+0x24
ffffba81`8c64f620 fffff800`4853ff35 : 00000000`00000003 00000000`00000002 00000000`00000000 00000000`00000008 : nt!PpmIdleExecuteTransition+0xeff
ffffba81`8c64fa00 fffff800`4863da5c : 00000000`00000000 ffffe600`23940180 ffffe600`23950100 ffff8382`0eaf2700 : nt!PoIdle+0x345
ffffba81`8c64fb60 00000000`00000000 : ffffba81`8c650000 ffffba81`8c649000 00000000`00000000 00000000`00000000 : nt!KiIdleLoop+0x2c
STACK_COMMAND:  kb
THREAD_SHA1_HASH_MOD_FUNC:  73c987e2e48d368e307edaa2f88b043119b02c66
THREAD_SHA1_HASH_MOD_FUNC_OFFSET:  fd7dc44eef7b5e04b2707f0ed15e7e97ee1448ad
THREAD_SHA1_HASH_MOD:  b803b7c11c52d0ad6df719f6be71385e898408f8
FOLLOWUP_IP:
fffff803`b2bc13f3 4585c9          test    r9d,r9d
FAULT_INSTR_CODE:  75c98545
SYMBOL_STACK_INDEX:  6
SYMBOL_NAME:  intelppm!MWaitIdle+23
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: intelppm
IMAGE_NAME:  intelppm.sys
DEBUG_FLR_IMAGE_TIMESTAMP:  0
BUCKET_ID_FUNC_OFFSET:  23
FAILURE_BUCKET_ID:  0x9C_GenuineIntel_STACKPTR_ERROR_intelppm!MWaitIdle
PRIMARY_PROBLEM_CLASS:  0x9C_GenuineIntel_STACKPTR_ERROR_intelppm!MWaitIdle
TARGET_TIME:  2018-06-24T15:48:04.000Z
OSBUILD:  17134
OSSERVICEPACK:  0
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK:  784
PRODUCT_TYPE:  1
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
OSEDITION:  Windows 10 WinNt TerminalServer SingleUserTS Personal
OS_LOCALE:
USER_LCID:  0
OSBUILD_TIMESTAMP:  2018-06-08 11:00:00
BUILDDATESTAMP_STR:  180410-1804
BUILDLAB_STR:  rs4_release
BUILDOSVER_STR:  10.0.17134.1.amd64fre.rs4_release.180410-1804
ANALYSIS_SESSION_ELAPSED_TIME:  3b1
ANALYSIS_SOURCE:  KM
FAILURE_ID_HASH_STRING:  km:0x9c_genuineintel_stackptr_error_intelppm!mwaitidle
FAILURE_ID_HASH:  {d82f1232-e6fd-ac41-d01e-ddeec73b684b}
Je suis sous Windows 10 et il faut que je mette a jour Windows 8 je suis un peu perdu.
Si quelqu'un peut m'aider merci d'avance.
Modifié par Le PoissonClown
Aide : mise en forme plus lisible.
il y a 48 minutes, Devii974 a dit :
bonjour,
votre windows est authentique et vous avez la licence ...
simple question ne pas le prendre mal...
Bonjour ! :c_happy:
Est-ce suite à une mise-à-jour de version de Windows ? Un multiboot ? Ça ressemble à un souci pour trouver et faire démarrer le système sur le disque dur…
Depuis les options de démarrage avancées, choisis « Outil de redémarrage système » et tentes de réparer le démarrage.
Si ça ne fonctionne pas, lis cette discussion pour suivre les réparations manuelles du démarrage :
Bonne soirée.
C'est un Windows 8.1 évoluer en 10, le 8.1 je l'ai acheter et le 10 quand Windows a fait son évolution gratuite.
Ok je vais essayer de réparer pour voir ce qu'il se passe.
Je sais pas si sa avoir quelque chose mais j'ai des pages bleus depuis que j'ai installer un jeu sa n'a peut être rien avoir mais bon une piste reste une piste.
En tout cas merci d'avoir répondu aussi vite.
Fait et toujurs pareilles branchements sont bien brancher, le bios a été remis à l'initial et toujours pages bleu avec les mêmes erreurs.
il y a 1 minute, Devii974 a dit :
J'ai démarré en mode sans échec et rien, pas de bsod je repace en normale et une bsod
le mode sans échecs vous fait démarrer le pc avec le minimum vital au pc ...
ainsi si vous n'avez pas de bsod pendant le mode sans echecs, le fait de redémarrer en mode normal .. Et qu'il re apparait un bsod, c'est qu'il y a un programme qui se lance mais en mode normal mais qui ne se lance pas en mode sans échecs
il faudrait trouver le quelle ...
pour cela vider toutes les pages dans les journaux évènement pour que l'ont y voient les derniers erreurs ou crash et pas les anciennes
Bonjour, voilà après plusieurs jour sans bsod je me retrouve en machine check exception.
Je joue au mmo et lorsque les bsod arrive bizarrement mon jeu est en marche.
J'ai remarqué que il me déco souvent du server ou je suis.
- System
- Provider
      [ Name] Windows Error Reporting
- EventID 1001
      [ Qualifiers] 0
  Level 4
  Task 0
  Keywords 0x80000000000000
- TimeCreated
      [ SystemTime] 2018-07-05T16:50:13.271340300Z
  EventRecordID 21752
  Channel Application
  Computer pcelina
  Security
- EventData
      0x9C_GenuineIntel
      BlueScreen
      Non disponible
      0737d9bc-ac18-43b1-87a3-855ea1b89d83
      9c
      ffffce006a14bc80
      10_0_17134
      0_0
      768_1
      \\?\C:\WINDOWS\Minidump\070518-23343-01.dmp \\?\C:\WINDOWS\TEMP\WER-206671-0.sysdata.xml \\?\C:\WINDOWS\MEMORY.DMP \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER65EF.tmp.WERInternalMetadata.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER65F0.tmp.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER660E.tmp.csv \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER661F.tmp.txt
      C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Kernel_9c_63587bc1dddbe8aa7b676680511ddbb732f561d_00000000_cab_05d7a067
      9ebbfbb2-4e43-47b3-94c5-2ae78a096dc6
      268435456
- System
- Provider
- EventID 1001
      [ Qualifiers] 0
  Level 4
  Task 0
- TimeCreated
  EventRecordID 21752
  Channel Application
  Computer pcelina
  Security
- EventData
      0x9C_GenuineIntel
      BlueScreen
      Non disponible
      9c
      ffffce006a14bc80
      10_0_17134
      0_0
      768_1
      268435456
genuine intel est en rapport a se que je peut comprendre au CPU " processeur "
a combien êtes vous a la température quand il shunt ?
vous avez le logiciel Speccy
https://www.ccleaner.com/speccy
télécharger le faite un relevé de vos température...
une fois fait, aller sur le jeux et jouer et de temps en temps aller voir ... a cmb vous êtes a la température
Dsl de vous faire courir comme cela, mais les erreur et bug écran bleu de Windows c'est pas évident a déterminé comme cela.
Bonjour, j'ai refais l'installation du système, ordi allumé toute la matinée et rien je lance le jeu et la de nouveau une page bleu avec les mêmes code erreurs. J'ai tout réinstaller donc je ne sais plus trop quoi faire.
il y a 26 minutes, Devii974 a dit :
Yop là
il faudrait peut être se rendre dans le forum de ce jeu en question ...
il y a en effet peut être des réglages dans le setup graphisme etc
tient nous au jus ;)
ok je vais aller voir, mon copain joue aussi a ce jeu est ce qu'il pourrait y avoir un conflit. on est tous les deux relié par câble à la box.
